Civil 3D Forum
DEM File Import
1 REPLY 1
232 Views, 1 Reply
DEM File Import
I'm trying to import DEM file data into a drawing with other geospatiailly referenced data, but I can't figure out how to go about importing the DEM. I've also tried downloading the Grid Ascii file format DEM file as well.
I've tried creating a surface from a DEM file, as well as using the "data connect" feature in mapper. Either way, I can't seem to get Civil 3D to recognize either of the file formats.
I can't find anything useful in the help system that explains to me what a DEM file should look like, or how to convert a standard NED DEM file format to a file type that Civil 3D supports.
Can anyone get me pointed in the right direction?
Thanks.
1 REPLY 1
Did you downloads an STDS then convert to DEM? This tends to be what I
see. My suggestion is to create a TIN, then add the DEM file as part of
that TIN. If you do this, C3D will perform a transformation that it
won't do if you just build direct from TIN. Don't ask me why.
If you happen to own a copy of Mastering, we look at this exact
procedure on Page 123. Hope this helps.
James Wedding, P.E.
Engineered Efficiency, Inc.
The Site: www.eng-eff.com
The Blog: www.civil3d.com
The Book: www.masteringcivil3d.com
Mac Book Pro C3D SP2, XP SP2, 2GB
Rail Community
