When labeling feature lines we would like to have an option under content properties so that not only can i see the grade/slope of the line but also the vertical difference.
End result will be that I label a line with a style that contains the slope above the line and also the vertical difference (delta) below the line.
Thanks.
HI Jeff,
Thanks for the replies.
I attached a screen shot of the label editor and the result of the available expressions.
How can I have the label perform the subtraction function? As I see it only displays certain properties that are available...I tried placing the start Z and end Z in a parenthesis, separated by the minus sign, but the label does not compute the two elevations. The label is only displaying the 2 elevations in a parenthisis and separtaed by a dash.
Where can I create an expression that will perform any math functions if we feed it the proper variables? Is that expression able to be inserted in the label style?
Thank You,
DK
When I punch this in, I get a pop-up error : "undefined property"
Do I need to add this value into available properties somewhere?
