My gut instinct says your trouble is centered around the DEM file.
set the surface to display the TIN lines. Explode the DEM TIN, and then create a "new" surface from those 3D lines that you got from exploding the DEM.
Not only will your file size drop DRASTICALLY, but your stability will become better.
__________
Craig T. Bailey, PE, LLS
Bailey Engineering
