I am having issues with phantom parcels. Doing a CrtlA command shows 827 parcels in my template that I would like to get rid of, but can't seem to delete. Anyone find a fix for this?
I've attached the drawing I am using for my template.
Solved by Jeff_M. Go to Solution.
I see them with ctrl+A. Would help if I re-read the OP 🙂
rl_jackson had the right idea: rebuild the template from scratch.
Rick Jackson
Survey CAD Technician VI
Joe Bouza
John Mayo
I'll try that. Any extra steps that I can take out from this process will make this easier for the masses.
Speaking of brute force, you can walk through the ObjectIds in modelspace, see the Sites (GUIDS) and even change their name. Sadly Site.Erase returns eNotApplicable, all Get*Ids come up 0.
Did you make it any farther?
Looks like its still happening in 2016.. I think it actually comes from exploding parcels that had overlapping segments?
Either way its bloody annoying. Rebuilding drawing now.
Regards
Is there a solution to this issue yet. I have 1002 parcels I cannot delete. Tried everything!
-Cory
Just getting back to this post now, and that suggestion worked! Thank you for pointing that out Jeff!
Read Jeff's reply regarding deleting parcels. It involves AutoCAD and it worked for me.
