tm
Member
tm
Message 1 of 10 (10,995 Views)
Delete key doesn't work, Can't edit text
10995 Views, 9 Replies
03-04-2009 04:11 PM
Any ideas? I have to go up to cut and select the object to delete. Also when I click on text the edit dialogue box doesn't come up. I have to go to properties to edit.
Make sure the Pickfirst system variable is set to
1
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Any
properties to edit.
*Jeff Mishler
Message 2 of 10 (10,995 Views)
Re: Delete key doesn't work, Can't edit text
03-04-2009 04:21 PM in reply to: tm
1
Any
properties to edit.
tm
Member
tm
Message 3 of 10 (10,995 Views)
03-04-2009 05:12 PM in reply to: tm
Thanks Jeff your awesome!
Member
stiedemann
Message 4 of 10 (10,995 Views)
04-28-2009 09:18 AM in reply to: tm
I have had the same problem a couple of times already and the only way to remedy the situation is to completely uninstall and re-install Civil3D. My Problem started with not being able to edit text, then not being able to use the delete key, and then the right click options pop-up box becomes unusable. I have re-installed Civil 3D for the third time and now my text editing by double clicking the text is not working. Can anyone help on this before I have to re-install for a forth time???
Member
stiedemann
Message 5 of 10 (10,995 Views)
tm
Member
tm
Message 6 of 10 (10,995 Views)
04-28-2009 01:29 PM in reply to: tm
Check out Jeff's reply on my post. This worked like a charm for me. I have not had the problem again.
Member
stiedemann
Message 7 of 10 (10,995 Views)
04-28-2009 01:37 PM in reply to: tm
I tried that PICKFIRST command which didn't work for the text editing but the DBLCLKEDIT command worked for that. I still can't figure out why the right click properties is not working, but i am on the hunt
New Member
amgedgoga
Message 8 of 10 (9,020 Views)
12-01-2012 03:41 AM in reply to: stiedemann
try "audit" and fix all, i think it will be usefull, i ahd same problem before
Member
peterchrien
Message 9 of 10 (8,593 Views)
01-24-2013 02:54 AM in reply to: tm
PickFirst worked for me very well :smileyhappy: thx
Member
meihum
Message 10 of 10 (7,284 Views)
05-10-2013 02:14 AM in reply to: amgedgoga
audit worked for me - cheers
