Civil 3D Forum
Delete key doesn't work, Can't edit text
12 REPLIES 12
Message 1 of 13
32189 Views, 12 Replies
Any ideas? I have to go up to cut and select the object to delete. Also when I click on text the edit dialogue box doesn't come up. I have to go to properties to edit.
Tags (1)
12 REPLIES 12
Message 2 of 13
Make sure the Pickfirst system variable is set to
1
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Any
properties to edit.
Message 3 of 13
Thanks Jeff your awesome!
Message 4 of 13
I have had the same problem a couple of times already and the only way to remedy the situation is to completely uninstall and re-install Civil3D. My Problem started with not being able to edit text, then not being able to use the delete key, and then the right click options pop-up box becomes unusable. I have re-installed Civil 3D for the third time and now my text editing by double clicking the text is not working. Can anyone help on this before I have to re-install for a forth time???
Message 5 of 13
Message 6 of 13
Check out Jeff's reply on my post. This worked like a charm for me. I have not had the problem again.
Message 7 of 13
I tried that PICKFIRST command which didn't work for the text editing but the DBLCLKEDIT command worked for that. I still can't figure out why the right click properties is not working, but i am on the hunt
Message 8 of 13
amgedgoga
try "audit" and fix all, i think it will be usefull, i ahd same problem before
Message 9 of 13
peterchrien
PickFirst worked for me very well 🙂 thx
Message 10 of 13
in reply to: amgedgoga
audit worked for me - cheers
Message 11 of 13
drafting605
Jeff Mishler, you're the freaking man!!! Thank you!!!
Quick question, how does this happen?...
Message 12 of 13
Hidden_Brain
in reply to: drafting605
usually happens due to a CAD crash.
Message 13 of 13
drafting605
in reply to: Hidden_Brain
Thank you! I guess I am going to have to change it often lol
Rail Community
