tm
Member
0 Kudos
Post 1 of 13
Delete key doesn't work, Can't edit text
12877 Views, 12 Replies
03-04-2009 04:11 PM
Any ideas? I have to go up to cut and select the object to delete. Also when I click on text the edit dialogue box doesn't come up. I have to go to properties to edit.
Make sure the Pickfirst system variable is set to
1
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Any
properties to edit.
*Jeff Mishler
Post 2 of 13
Re: Delete key doesn't work, Can't edit text
03-04-2009 04:21 PM in reply to: tm
1
Any
properties to edit.
tm
Member
0 Kudos
Post 3 of 13
03-04-2009 05:12 PM in reply to: tm
Thanks Jeff your awesome!
Member
0 Kudos
Post 4 of 13
04-28-2009 09:18 AM in reply to: tm
I have had the same problem a couple of times already and the only way to remedy the situation is to completely uninstall and re-install Civil3D. My Problem started with not being able to edit text, then not being able to use the delete key, and then the right click options pop-up box becomes unusable. I have re-installed Civil 3D for the third time and now my text editing by double clicking the text is not working. Can anyone help on this before I have to re-install for a forth time???
Member
0 Kudos
Post 5 of 13
tm
Member
0 Kudos
Post 6 of 13
04-28-2009 01:29 PM in reply to: tm
Check out Jeff's reply on my post. This worked like a charm for me. I have not had the problem again.
Member
0 Kudos
Post 7 of 13
04-28-2009 01:37 PM in reply to: tm
I tried that PICKFIRST command which didn't work for the text editing but the DBLCLKEDIT command worked for that. I still can't figure out why the right click properties is not working, but i am on the hunt
New Member
0 Kudos
Post 8 of 13
12-01-2012 03:41 AM in reply to: stiedemann
try "audit" and fix all, i think it will be usefull, i ahd same problem before
Member
0 Kudos
Post 9 of 13
01-24-2013 02:54 AM in reply to: tm
PickFirst worked for me very well :smileyhappy: thx
Member
0 Kudos
Post 10 of 13
05-10-2013 02:14 AM in reply to: amgedgoga
audit worked for me - cheers
