Civil 3D Forum
Delete a style in use
10 REPLIES 10
Message 1 of 11
IanMcClain
1502 Views, 10 Replies
Is there a nuclear option for deleting a style that is not in use?
Backgound: I have a drawing that is painfully slow to work in, saves are particulary excruciating. After removing some MOOs (Multiply owned objects), wblocking into a new dwg and dozens of audit's, purges and style purges there still exists a general line label style that was one fo the MOOs. The objects that used the style appear to be gone from the drawing, however the "Replace with..." option indicates the style is still has 9 referneces. Selecting another style to replace the offender does nothing at this point; there are still 9 refernces (initially there were 200+). I've scoured the settings for other refernces, but found none.
Ian McClain
10 REPLIES 10
Message 2 of 11
jmayo-EE
in reply to: IanMcClain
Did you try the purgestyles comand? Note a bit of a bug will require users to slide the scroll bar to see the list populate.
John Mayo
Message 3 of 11
jmayo-EE
Message 4 of 11
IanMcClain
in reply to: jmayo-EE
I have tried that, to no avail. The drawing seems to think their are still references to this style, so it's not showing up in the purge style list.
Ian McClain
Message 5 of 11
rkmcswain
If it's not available for purge, then it's probably in use.
Have you tried right-click, then "Find References"?
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 11
rkmcswain
I had forgotten all about that. That was a good one...
Message 7 of 11
IanMcClain
in reply to: rkmcswain
I have: it returns "Gneral Segemet Label\". Doulble clicking this usually takes me right to the refence, but not in this case. I've scoured the settings tree and come up with nothing.
Ian McClain
Message 8 of 11
jmayo-EE
If you open the Add Labels dialog box is this label style listed as being current for any of the line/cuver options (single seg, mult seg, etc)? If so change the current style to something else.
John Mayo
Message 9 of 11
IanMcClain
Unfortunately, that is not the case.
Ian McClain
Message 10 of 11
AllenJessup
Does the style persist if you WBlock out the drawing and insert it in to a new drawing?
Allen
Allen Jessup
CAD Manager - Designer
Message 11 of 11
IanMcClain
in reply to: AllenJessup
It does, and that is using the object option (as opposed to entire drawing).
Ian McClain
Rail Community
