Is there a nuclear option for deleting a style that is not in use?
Backgound: I have a drawing that is painfully slow to work in, saves are particulary excruciating. After removing some MOOs (Multiply owned objects), wblocking into a new dwg and dozens of audit's, purges and style purges there still exists a general line label style that was one fo the MOOs. The objects that used the style appear to be gone from the drawing, however the "Replace with..." option indicates the style is still has 9 referneces. Selecting another style to replace the offender does nothing at this point; there are still 9 refernces (initially there were 200+). I've scoured the settings for other refernces, but found none.
John Mayo
John Mayo
I have tried that, to no avail. The drawing seems to think their are still references to this style, so it's not showing up in the purge style list.
I had forgotten all about that. That was a good one...
I have: it returns "Gneral Segemet Label\". Doulble clicking this usually takes me right to the refence, but not in this case. I've scoured the settings tree and come up with nothing.
John Mayo
Does the style persist if you WBlock out the drawing and insert it in to a new drawing?
Allen
Allen Jessup
CAD Manager - Designer
It does, and that is using the object option (as opposed to entire drawing).
