I am using 2010. When I use Inquiry to list curve data I get the delta in decimal degrees and I have to use same to create the curve. When I create a curve table, it gives me the delta in DMS. I've checked the units under Settings and the only option is Degrees, Radians and Grads.
Is there a way to do it all in DMS?
Thxs.
David
Go to your Ambient Settings tag, Select Angle and change the format to whatever DMS setting you desire.
