Civil 3D Forum
Degree of Curve Label
4 REPLIES 4
jak79
1467 Views, 4 Replies
I am using 2010 Civil 3D. I would like to include in my alignment curve label the "degree of curve". Any help or a practice how to create this is appreciated.
4 REPLIES 4
in reply to: jak79
Hopefully you know how to use the Label Style Composer. In the Text
Component Editor there are two versions, Degree of Curvature by Arc and the
Degree of Curvature by Chord.
Bill
wrote in message news:6239599@discussion.autodesk.com...
appreciated.
jak79
in reply to: jak79
Thanks for the help Bill. I attached an image of the available properties in my Text Component Editor. I don't have the two you mentioned. Am I in the right spot or do I need to add those in some how?
in reply to: jak79
Those properties are in the Alignment Curve label and not in the General
Curve label.
Peter Funk
jak79
in reply to: jak79
Thanks Peter that was what I needed. Thanks again for your time.
Rail Community
