Civil 3D Forum
degree of curvature
8 REPLIES 8
Message 1 of 9
thorius
1328 Views, 8 Replies
degree of curvature
Has anyone figured out to get the degree of curvature (DOC) for a curve in an alignment to be reported for Civil 3D 2007 like was reported in the 2006 version?
8 REPLIES 8
Message 2 of 9
in reply to: thorius
Do you need it for highway or railroad curves?
wrote in message news:5263131@discussion.autodesk.com...
version?
Message 3 of 9
thorius
I need it for highway curves.
Message 4 of 9
You can add an expression to the curve label... see the attached gif file.
Karen Dowling
Autodesk ISD Test Development
Message 5 of 9
How does one go about getting degree of curvature (D) to display in a label for a PI in C3D 2006?
Message 6 of 9
tvlohrman
Ok, but how do I get the radius into this calculation?
Thank you,
Tom
Message 7 of 9
One would assume it will get the radius from the
selected curve.
Bill
Ok,
but how do I get the radius into this calculation? Thank you,
Tom
Message 8 of 9
tvlohrman
Radius was not a choice in the expression inset property list. Turns out that I was in the general label styles section, not the Alignment>label sytles>curve section. So, there are different choices available based on what area you are in.
Message 9 of 9
JamaL9722060
How to set and label the “degree of curvature”?
As the radius of the circular alignment is calculated from the “degree of curvature” (attached) then I couldn’t figure out how to change the default value or to label it (degree of curvature)
Thank you
Best
Jamal
Jamal Numan
Rail Community
