Typically that corrects it for me. Did you try adjusting the default number
of ranges? I have seen the problem, but not a way to conistantly reproduce
it. If the dwg is under 5mb I will take a look. nick.zeeben as listed
below.
Nick Zeeben
www.eng-eff.com
C3D 2007 SP1a
XP Tablet and Pro
wrote in message news:5271082@discussion.autodesk.com...
In the surface style, I tried changing the quantile / std. dev / equal
interval but that doesn't fix it. Shouild I look somewhere else?
This issue also occurs with the contour, elevations, slopes, and slope arrow
analysis types.. if that helps at all.
Josh
