I am working on a commercial development with multiple large tenants with multiple standards. To begin to verify the preliminary grading is in compliance, I use the slope arrow surface analysis type.
Due to my multiple standards, I find myself changing these values frequently. My question : Is there a way to make the slope arrow the default analysis type when you are in the surface properties dialog box?
I know it is not a major issue, but it is annoying and repetitive, having to go to the list box, and select slope arrow over and over again. One workaround I have considered to avoid this maddening situation is to make two surfaces, with each criteria assigned to the surface properties and simply paste the main surface into each. Then control which is visible based on what I need to look at.
