My pipe network sructures shown default sump depth 2.00m (attachemnt 01 & 2). In the rules Sump value is 0.00, also in
Is it possible to change the sump value for all structures globally?
In part builder - model parameters the ''FTh'' value is 300mm, using as a structure base slab thickness (attachment 02 & 03)
Please have a look!!
Thank you
najeeb
Solved by ccoles. Go to Solution.
Make sure you have ALL your rule sets your using to set sump depth to zero.
To set the new rules, go to 'Modify' on the ribbon, Click 'Pipe Networks', Expand the 'Modify' section, and click on 'Apply Rules' to select the structures you wish to change.
