The Description Key Sets is only for importing points or field books;
correct? I had already changed the Feature Settings under the Point
Collection to default to my styles prior to posting, but no luck. this is
what I have set and the points still come in w/o a point or label style???
"mjfarrell" wrote in message news:6000064@discussion.autodesk.com...
> The tutorial here http://www.primeservicesglobal.com/tutorials/Points.zip
> will show you how set up your description keys so that imported points
> assume the proper style.
> And or you must go the Settings Tab, and be sure to find the Points
> collection, the Rt-Click on it and adjust the Feature Settings, you can
> set the default styles and description key set to use there.
> Or you may do this under the Create Points command Settings.
