Anyone know where I have to go to to change the default Parcel and Parcel Segment layers? Been tearing my hair out trying to find it, with no luck. We are not on NCS layering.
Please share your success so others that may not know can benifit
Joe Bouza
as i remember it, there are 2 places.
In the Masterview Drawing Settings
the Parcel Commands "creat parcel from ..."
There may be one other, but I can't remember. I don't have access to
Civil 3d at home.
Surveyor Lee
This took me some machinations to change. Confusingly, it is not in the Toolspace area for parcels as mentioned above (see below, some settings are). To change the default layer for new parcels, follow the following procedure.
Toolspace > Settings > *right click* on [File Name] > *select* Drawing Settings > Object Layers > Parcel Layer.
However, related is the correct procedure for changing default label styles for new parcels, which importantly will influence the formation of tables.
Toolspace > Settings > [File] > Parcel > Commands > CreateParcelfromObjects* > Default Styles
*You can also modify other commands such as CreateParcelByLayout.
