Distinguished Contributor
9 Kudos
Post 11 of 27
Re: Dealing with AECC_COGO_POINTs
10-31-2012 04:48 PM in reply to: J_Seeds
To get around that, I went in and created a special text style the is annotative at 1"=1'.  I created mine at 0.06' (Leroy 60).
Tne when the points are inserted at 1"=1', they come in corrrectly.  Since the text type is annotative, the size will automatically rescale to Leroy 60.  So you can change the scale and the points and symbols will re-scale.
Surveyor Lee
485 Kudos
Post 12 of 27
11-01-2012 05:49 AM in reply to: J_Seeds
You might be able to handle it using an expression the way I handle the text height. See my post [Here].
Allen
264 Kudos
Post 13 of 27
11-01-2012 07:38 AM in reply to: AllenJessup
That looks familiar!  :smileywink:
Credit where credit is due! Give kudos or accept as solution whenever you can.
485 Kudos
Post 14 of 27
11-01-2012 07:44 AM in reply to: troma
Yes. I knew it had been mentioned.:smileyhappy: But sometimes a second opinion, although exactly the same, will help someone along the right track.:smileywink:
Allen
264 Kudos
Post 15 of 27
11-01-2012 08:17 AM in reply to: AllenJessup
Fair 'nuf.  Nice theory. :smileywink:
485 Kudos
Post 16 of 27
11-01-2012 08:22 AM in reply to: troma
troma wrote:
Nice theory
And I'm standing buy it! Truly I did remember that it had been mentioned. But I only reread the original post. So I hadn't remembered you'd covered it in full detail.
Redundancy never hurts. Belt and suspenders and all that. How many people here in the North East wish they had a redundant power supply!
Allen
264 Kudos
Post 17 of 27
11-01-2012 09:26 AM in reply to: AllenJessup
Truly, tautology is so redundant!
The 'nice theory' I was referring to is that repetition will actually persuade someone to pay attention; not that you knew you were repeating. I believe you.
0 Kudos
Post 18 of 27
11-01-2012 09:53 AM in reply to: troma
Allen, I tried your expression solution and it does what I want when the point label is in its "home position" however I'm not able to apply the expression to the text height in dragged state mode. Am I missing something? BTW I'm working in 2010 not sure if 2012 or 13 is different.
264 Kudos
Post 19 of 27
11-01-2012 10:14 AM in reply to: J_Seeds
Can you set the dragged state to 'As Composed' ?
485 Kudos
Post 20 of 27
11-01-2012 10:15 AM in reply to: J_Seeds
In the Label Style Composer, on the Dragged State tab, under Dragged State Components the Display must be As Composed not Stacked Text. You can't put in an expression for text height in the stacked text.
Allen
