Hi
I am new to AutoCAD Civil 3D. Just wondering if anybody can give me a good definition of the term "daylight" please.
Solved by fcernst. Go to Solution.
In civil engineering this term typically means where a proposed feature meets existing ground.
As in where does my cut slope see daylight, or where does the outfall pipe see daylight. A fill slope also daylight but it was never really in the dark so the anecdote doesn't fit quite so neatly.
Joe Bouza
I believe the derivation is from an agricultural origin for draining fields through embankments. "Run this pipe to daylight in order to drain this area".
Fred
You have been very helpfull.
Roman Shirshov-Menzel
Graduate Civil Engineer
