Member
DenverDave
Message 1 of 16 (1,139 Views)
Daylight to offset with maximum slope
1139 Views, 15 Replies
11-07-2012 10:55 AM
It seems simple but i can't find the right perameters.
I need to daylight to an offset, to create a clear zone/fall zone, but it must have a maximum slope of 6:1. If no daylight is found at the offset and maximum slope, then grade at the maximum slope to the offset then daylight to the target suface at a steeper slope.
IT SEEMS LIKE IT SHOULD BE EASY BUT I CAN'T FIND IT.
Steve's solution will work.  His post needs more detail.  What his image shows is that the conditional subassembly is moved over X feet.  There you can test the depth of cut or fill.  We know what this needs to be - based on the slope times the offset.  At the ends of the conditonal sub assemblies, Move the remaining subassemblies back X feet.
Instead of moving subassemblies, I use generic links with the omit option set to Yes.  That helps me keep the pieces connected correctly, and allows for easy editing of the offset distances.  The following image shows this with the width and slope generic link.
The final assembly would look something like this:
Employee
peterfunkautodesk
Message 2 of 16 (1,133 Views)
Re: Daylight to offset with maximum slope
11-07-2012 11:14 AM in reply to: DenverDave
I don't see any of the standard SA that would do this. The daylight standard gets close, but would have a fixed clear zone slope.
You should be able to make it with Subassembly Composer pretty quickly.
1. Set a test point on the surface at the offset
2. Check the slope to the test point
    A. If it is below 6:1 add a daylight point and link
    B. If it isn't, add a point at 6:1, and then daylight from there
I'm not sure what you need in a cut.
Peter Funk
Peter Funk
sboon
Message 3 of 16 (1,107 Views)
11-07-2012 10:21 PM in reply to: peterfunkautodesk
It may not be possible using a single sub,  but it's definitely possible to do it in an assembly.
Employee
peterfunkautodesk
Message 4 of 16 (1,096 Views)
11-08-2012 06:33 AM in reply to: sboon
Steve,
I considered that, but I don't think that doesn't provide the solution where you can daylight at less than 6:1. I think this could be done with a pretty simple PKT file made with Subassembly Composer.
Peter Funk
Peter Funk
Member
DenverDave
Message 5 of 16 (1,090 Views)
11-08-2012 07:05 AM in reply to: peterfunkautodesk
Although it may be time to learn the Subasembly Composer, I currently have no idea how to use it. I am hoping for a solution using some combination of the standard assemblies.
Member
DenverDave
Message 6 of 16 (1,087 Views)
11-08-2012 07:10 AM in reply to: sboon
Can you provide a little more detail about your sugested solution? Can this solution be adapted to daylight at less than 6:1 at the specified offset?
Employee
peterfunkautodesk
Message 7 of 16 (1,079 Views)
11-08-2012 08:20 AM in reply to: DenverDave
Here is a quick version of a SA that should do what you are looking for in Fill. I didn't add link and point codes, but it might get you started.
Peter Funk
Peter Funk
sboon
Message 8 of 16 (1,075 Views)
11-08-2012 08:34 AM in reply to: DenverDave
If we assume for the moment that we're only dealing with the scenario on the left side of your sketch then there are several subs which might work.
  1. LinkOffsetOnSurface would always tie in at the max offset distance, but the daylight point could be anything above the max. 6/1 limit.  It could easily end up being a cut slope also.
  2. DaylightInsideROW would allow you to specify a typical slope, which would get steeper, up to the max if necessary.
  3. DaylightMaxOffset or DaylightMaxWidth are similar to 2.
  4. DaylightToOffset appears to have the same behaviour as 1, but with parameters for lined materials and rounding.
Valued Mentor
david.zavislan
Message 9 of 16 (1,062 Views)
11-08-2012 09:37 AM in reply to: DenverDave
David Zavislan, P.E. | Wood Rodgers, Inc.
sboon
Message 10 of 16 (1,048 Views)
11-08-2012 10:31 AM in reply to: david.zavislan
David jumped ahead of me to the complete solution, rather than a step by step discussion.
His graphics are better too. :smileywink:
