Civil 3D Forum
Daylight Overlapping issue
3 REPLIES 3
onsionsi1
610 Views, 3 Replies
Hello There,
I faced some problem that the bench daylight intersect and overlap each other in some areas and also in view edit corridor section the link code for this daylight and other subassmbly didn't appear because there are some additional link code appeared at this view edit corridor section i don't know where it came from so this issue is clarifying in attached file.
Your advice please
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
3 REPLIES 3
mathewkol
in reply to: onsionsi1
Try an out of the box code set style in the section editor and you should see the daylight links.  Make sure the sectino editor is using that code set style, don't just apply it to your codrridor.
Regarding the overlaps, if your site is super steep, then the daylight will just keep going until it intersects the ground, overlap or not.  Especially with a curvy corridor such as yours.  Tough to say exactly if there is a problem without opening the file itself.   Thoush your section that shows across the entire site would indicate that this shouldn't happen.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
onsionsi1
in reply to: mathewkol
Yes Mr. Math
My project is in super steep site but my issue is that i can't found the link code to edit and minimze distance that target the surface because there is appear additional link code and point code as appeared in attached file before.
Thank you.
THEBOLT
Hey, did u find any solution ? If  yes then help me. Im having same overlapping problem.
Rail Community
