Civil 3D Forum
Daylight/CCorridor Overlapping
5 REPLIES 5
THEBOLT
2317 Views, 5 Replies
I created corridor using daylight bench (7:1_V:H  slope, width 3m & vertical height 10m_max). In some of curvy part, corridor overlaps. And, in section i get multiple sub-assembly lines.
Is there way to create continuous sub-assembly not overlapping eachother and actual section as it supposed to be ?
(Googling and other posts didn't help)
5 REPLIES 5
sboon
in reply to: THEBOLT
It appears that your alignment has bends in it, which means that you will have corridor sections that overlap.  About the only choice you have in this case would be to use grading objects instead of a corridor.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
THEBOLT
in reply to: sboon
Yes, exactly. My alignment has bends in it.
I did try grading as well but the problem is I cannot grade to specific height and to the target surface at the same time. Is this possible ?
Thanyou for replying...
doni49
What you're dealing with has been dubbed the "Bow Tie Effect".
GIve the following link a read.
http://www.civil4d.com/2009/09/bowties-be-gone/
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
OmareMA
Delete the overlapping portion of corridor surface..
Than create polylines between deleted areas.
Than afterwards through contour option from new surface create a surface. Than paste in existing Surface. You are done.
I created daylight benches using this method.
You can view the image at
www.fb.com/autodeskcollege
OmareMA
Than create polylines between deleted areas of similar shape.
Than afterwards through contour option from new surface, create a surface. Than paste in existing Surface. You are done.
Grading method will not work on benches.
You can view attached Image of my work.
Rail Community
