Hi All,
Please see attachment of cross section. My datum jumps up to the point where my subassembly (ShapeTrapezoidal) connects to the back of curb. What do I need to change so the datum will connect and go vertical to the bottom of the subassembly after the curb extension?
Solved by awood. Go to Solution.
In the Corridor Properties - Surfaces tab - set the Overhang correction for the datum surface to bottom links and see if that helps.
HTH
AWood
