AutoCAD Civil 3D General Discussion
Active Member
simon
Message 1 of 10 (524 Views)
Accepted Solution
Data Shortcuts
524 Views, 9 Replies
10-31-2012 03:25 AM
I've just used Data Shortcuts for the first time but I've found that I can only reference in Surfaces and Alignments.  Is this correct? The file I am creating my model in, has Corridors/Feature Lines/Gradings as well but I can't create Data Shortcuts for these? or am I missing something?
Xreffing allows you to see, for example, the contours of a surface built in another base drawing, as well as label the contours. However, xreffing does not allow you to use the surface in profile views, or to do volume calculations, to name a few things that require data referencing the object.
Same with other objects: an xref'd alignment lets you see the alignment, but does not allow you to label it or reference it in the drawing in any way. For this you need data references.
No worries - I use this technique to produce my plotted sheets i.e. Xref the engineering drawings and label the Xref.
The technique also works well for surfaces e.g. contour labels, slope labels etc etc
*Expert Elite*
LisaPohlmeyer
Message 2 of 10 (511 Views)
Re: Data Shortcuts
10-31-2012 05:36 AM in reply to: simon
No, you're not missing anything.  I believe the intent is that you use those features to create surfaces, which you can dref. You can also xref the corridor into a drawing, dref the alignment and create sample lines for cross sections.  Be sure not to put all your civil 3D objects in one drawing.  Keeping the data separate will help in the case of corruption.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Distinguished Mentor
castled071049
Message 3 of 10 (499 Views)
Re: Data Shortcuts
10-31-2012 06:10 AM in reply to: simon
In the Prospector tab in Toolspace, under Data Shortcuts at the bottom, you will see that only Surfaces, Alignments, Pipe Networks, and View Frame Groups can be Data Shortcuts.
Active Member
simon
Message 4 of 10 (494 Views)
Re: Data Shortcuts
10-31-2012 06:50 AM in reply to: simon
Thanks for the advice. I had been hoping that I could just dref into a drawing the components of the model without needing to xref the whole model drawing.  By xreffing in the whole model drawing then I don't see the benefit of using the drefs in the first place?
castled071049
Message 5 of 10 (487 Views)
Re: Data Shortcuts
10-31-2012 07:03 AM in reply to: simon
*Expert Elite*
neilyj
Message 6 of 10 (475 Views)
Re: Data Shortcuts
10-31-2012 07:55 AM in reply to: castled071049
I believe that Xref'd civil objects can be labelled e.g. surfaces & alignments
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
castled071049
Message 7 of 10 (472 Views)
Re: Data Shortcuts
10-31-2012 07:58 AM in reply to: neilyj
Yes, as I said, labeling is possible with xrefs. But you cannot use xref'd C3D objects for other purposes: e.g. surfaces for volume calculations, or referencing an alignment in a station/offset label, to name a couple of things.
*Expert Elite*
neilyj
Message 8 of 10 (469 Views)
Re: Data Shortcuts
10-31-2012 08:01 AM in reply to: castled071049
neilyj
castled071049
Message 9 of 10 (464 Views)
Re: Data Shortcuts
10-31-2012 08:08 AM in reply to: neilyj
Yes, there are certain (but not all) labels that can be added to xref'd C3D objects. My point was to show the OP why data shortcuts are sometimes more useful than an xref. There are many things you can't do with an xref'd C3D object that you can with a dref'd object. He was wondering what the purpose of data shortcuts was.
I do stand corrected, however, on adding station/offset labels to xref'd alignments. I did not know this would work, but it does. I learned something new today.
*Expert Elite*
neilyj
Message 10 of 10 (454 Views)
Re: Data Shortcuts
10-31-2012 08:55 AM in reply to: castled071049
neilyj
Need installation help?
