I've created my pipes in my piping plan, data shortcut them into my proposed drawing. I than create my view frames in the proposed drawing and create my sheets. However, my surfaces nor any pipes show up in my sheets created. Any ideas why?
Andy W.
Solved by sboon. Go to Solution.
Using a reference to move model data from drawing A into drawing B doesn't mean that it will automatically display that data in drawing C. The sheet creation wizard has an option to send other data to the sheet files.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
First, thanks for the response, even after I really didn't give you a whole lot of information, such as what release I'm using and so forth. But my problem was simply that I was not data shortcut everything into my proposed drawing. I did not include the profiles. I assumed that I did the alignment and pipe network that I did not have to do profiles.
So again thanks for helping us production guys who are trying to get projects done the correct way!
Andy
