I cant get this one. I have created an aligmnent in a drawing and created a shortcut. When I data shortcut that alignment into drawing "A", its all good. Alignment starts at station 10+00. When I do the same data shortcut into drawing "B" the alignment is starting at station 0+83.33. Why?
Thats what I thought. These drawings were done out of house for starters. The alignment drawing is set to decimals with insertion scale at inches. the drawing that works is set to the same. and so is the one that isn't working. They are all set to the same, so I don't get it???
Perfect. Thanks so much. You are correct. It was the drawing settings under the settings tab in the prospector. One was inches and on was feet.
you can take the rest of the day off...
