Civil 3D Forum
DATA SHORTCUT- SURFACES
6 REPLIES 6
ericbeal34
731 Views, 6 Replies
Im having trouble creating a surface data shortcut of a surface that has a paste surface in it. Could the surface paste be the reason a shortcut will not produce??
6 REPLIES 6
Adriano_cad
in reply to: ericbeal34
hello,
What is the message error has?
A fault in creating the shortcut can occur for several reasons, but so that we can help is necessary to know which type of error.
Adriano Oliveira
Diretor Soluções BIM MaxiCAD
MaxiCAD Soluções e Educação BIM.
Facebook | Twitter | LinkedIn
some text
ericbeal34
in reply to: Adriano_cad
There was no error message.
I just figured it out. Seems autocad did not like the surface name as it was too long. I simplified it and then it worked!!
Thanks.
Adriano_cad
Ok
You should be careful not to use special characters.
bye
Adriano Oliveira
some text
ericbeal34
none was used. just the name was too long. maybe too many characters.
sboon
It's not likely the source of the problem.  Creating the data shortcut should not have anything to do with how the surface is created.
Steve
Expert Elite Alumnus
ericbeal34
in reply to: sboon
The surface is sound. Done properly. Once the surface name was shortened, the shortcut created.
Lesson,
When creating complex surfaces, and/or having multiple surfaces in one drawing, use the description box to describe the surface buing built, do not try to describe it in the name box by short abbreviations .
Rail Community
