Civil 3D Forum
Data Shortcut - Profile
10 REPLIES 10
Message 1 of 11
sswanson
5874 Views, 10 Replies
I opened a new file and referenced in a data shortcut of a surface model object from which I then created  an alignment and profile, as well as creating a data shortcut of the alignment & profile, then saved the file as Drawing A.
My problem is that when I opened a new file Drawing B, and try to data reference just the profile,
all I get is the alignment and no profile.
So my question is why can't I data reference in the profile on another drawing?
This process worked when I data referenced in the surface model object.
        Steve Swanson
10 REPLIES 10
Message 2 of 11
Jay_B
in reply to: sswanson
Is this what you've tried?
From within File B:
Data Shortcuts listing on Prospector Tab of Toolspace>Alignments>Centerline Alignments>Alignment Name>expand Alignment Name>Profiles>expand Profiles>Profile Name>Rt. Click>Create Reference?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 11
Joe-Bouza
The alignment and profile should be created in the same file. Althought it seems, and c3d lets you, create them in different files it doesn't always work. don't know if you can call it a bug, but it is a c3d fact of life. sometimes it will work and sometimes it will not
Your Name
Your Name
Message 4 of 11
sswanson
in reply to: Jay_B
Hi Jay
Yes that is exactly what I did, but all I got was the centerline alignment.
                                         Steve
Message 5 of 11
sswanson
in reply to: Joe-Bouza
Hi Joe
Both the alingment and profile where created on the same file, Drawing A, but I can not bring in the data reference of the profile from dwawing A into Drawing B.
                                                     Steve
Message 6 of 11
Jay_B
Steve,
I didn't see any version info posted but it's working fine here using 2014 SP1.
In Prospector, did you drill down to Alignments>Centerline Alignments>Alignment Name>Profiles>Profile Name
In drawing B after creating the reference?
C3D 2018.1
C3D 2016 SP4
Message 7 of 11
sswanson
Jay
Yes that is what I did, and as soon as I did that the "Create  Profile Reference" menu appears with my source profile & alignment names,
profile style: Standard, profile layer 0, and profile label set: standard.   Then just the alignment appears. maybe it could be a layer problem,
but I still can not figure why the alignment appears, it should just the profile.
        Steve
Message 8 of 11
Joe-Bouza
That doesn't sound possible?
What Would you do with only a profile? They usually are part and parcel I think you have to deref the alignment first
Just the profile? and what would it be tied too?
Your Name
Your Name
Message 9 of 11
Jay_B
"I think you have to deref the alignment first"
I thought so too Joe, until I tried just that today when looking at this.
Created New dwg from dwt>save dwg>dref in surface pfl only.
It worked but of course it also brought the parent alignment along
for the ride as both appeared in prospector.
C3D 2018.1
C3D 2016 SP4
Message 10 of 11
sswanson
Hi Jay & Joe
I was out yesterday, so I just tried your suggestion and it worked.  This is great.
                           Thank you both for all your help
                                              Steve Swanson
Message 11 of 11
Joe-Bouza
HTH
Your Name
Your Name
Rail Community
