Valued Contributor
sswanson
Message 1 of 11 (194 Views)
Data Shortcut - Profile
194 Views, 10 Replies
02-03-2014 12:19 PM
I opened a new file and referenced in a data shortcut of a surface model object from which I then created  an alignment and profile, as well as creating a data shortcut of the alignment & profile, then saved the file as Drawing A.
My problem is that when I opened a new file Drawing B, and try to data reference just the profile,
all I get is the alignment and no profile.
So my question is why can't I data reference in the profile on another drawing?
This process worked when I data referenced in the surface model object.
        Steve Swanson
That doesn't sound possible?
What Would you do with only a profile? They usually are part and parcel I think you have to deref the alignment first
Just the profile? and what would it be tied too?
Hi Jay & Joe
I was out yesterday, so I just tried your suggestion and it worked.  This is great.
                           Thank you both for all your help
                                              Steve Swanson
Jay_B
Message 2 of 11 (180 Views)
Re: Data Shortcut - Profile
02-03-2014 01:19 PM in reply to: sswanson
Is this what you've tried?
From within File B:
Data Shortcuts listing on Prospector Tab of Toolspace>Alignments>Centerline Alignments>Alignment Name>expand Alignment Name>Profiles>expand Profiles>Profile Name>Rt. Click>Create Reference?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Joe-Bouza
Message 3 of 11 (175 Views)
02-03-2014 01:27 PM in reply to: sswanson
The alignment and profile should be created in the same file. Althought it seems, and c3d lets you, create them in different files it doesn't always work. don't know if you can call it a bug, but it is a c3d fact of life. sometimes it will work and sometimes it will not
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
sswanson
Message 4 of 11 (168 Views)
02-03-2014 01:44 PM in reply to: Jay_B
Hi Jay
Yes that is exactly what I did, but all I got was the centerline alignment.
                                         Steve
Valued Contributor
sswanson
Message 5 of 11 (164 Views)
02-03-2014 01:49 PM in reply to: Joe-Bouza
Hi Joe
Both the alingment and profile where created on the same file, Drawing A, but I can not bring in the data reference of the profile from dwawing A into Drawing B.
                                                     Steve
Jay_B
Message 6 of 11 (163 Views)
02-03-2014 01:49 PM in reply to: sswanson
Steve,
I didn't see any version info posted but it's working fine here using 2014 SP1.
In Prospector, did you drill down to Alignments>Centerline Alignments>Alignment Name>Profiles>Profile Name
In drawing B after creating the reference?
Jay
C3D 2014 SP2
Valued Contributor
sswanson
Message 7 of 11 (148 Views)
02-03-2014 02:19 PM in reply to: sswanson
Jay
Yes that is what I did, and as soon as I did that the "Create  Profile Reference" menu appears with my source profile & alignment names,
profile style: Standard, profile layer 0, and profile label set: standard.   Then just the alignment appears. maybe it could be a layer problem,
but I still can not figure why the alignment appears, it should just the profile.
        Steve
Joe-Bouza
Message 8 of 11 (137 Views)
02-03-2014 06:50 PM in reply to: sswanson
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Jay_B
Message 9 of 11 (133 Views)
02-03-2014 07:14 PM in reply to: Joe-Bouza
"I think you have to deref the alignment first"
I thought so too Joe, until I tried just that today when looking at this.
Created New dwg from dwt>save dwg>dref in surface pfl only.
It worked but of course it also brought the parent alignment along
for the ride as both appeared in prospector.
Jay
C3D 2014 SP2
Valued Contributor
sswanson
Message 10 of 11 (112 Views)
02-05-2014 07:58 AM in reply to: sswanson
Hi Jay & Joe
                                              Steve Swanson
