I have created a data shortcut to a surface using Civil3D 2011. When I create a reference to it in another drawing, it shows up in the Prospector but nothing shows up on the screen. I have played with the surface style and made sure all the layers were on and tried closing and reopening the drawing. I have also tried to reference it into a brand new blank drawing and I even tried to reference a surface in a different file that I have referenced several times before (in 2010). Every time I get the same results. It seems like the surface is there, but I just can't see it. Any thoughts?
Solved by gr8gonzo0. Go to Solution.
Well I solved my own problem. Although I had tried closing and opening the drawings, I did not try closing and open Civil3D entirely. This seemed to fix everything. Maybe this will help someone in the future.
