Active Contributor
randoshadow
Message 1 of 7 (355 Views)
Data Referenced Profiles bring in multilpe copies of Alignment
355 Views, 6 Replies
08-24-2010 04:50 PM
Has anyone had this issues...
I have a design file that has and alignment with 3 profiles (one surface profilke and two layout profiles)
All these are data referenced to the project. Then they are data referenced into a new file. I bring in one of the profiles that brings in the alignment. Lets call it "Main Street". Then I create another reference to another one fo the profiles and it brings in a copy of an alignment and calls it "Main Street (1)"
This is a pain because I cant get a profile view to show all the profiles because the profiles are associated with three different alignments "Main Street", "Main Street(1)", "Main Street(1)(1)"
This is only happening with one of the of the alignments. The other alignment has all its profiles listed under one alignment.
ANy idea why this is happening?
Randy
Product Support
SethHall
Message 2 of 7 (335 Views)
Re: Data Referenced Profiles bring in multilpe copies of Alignment
08-25-2010 05:48 AM in reply to: randoshadow
Hi Randy-
I am working on a similar issue for a user at the moment, and I was unable to reproduce this behaviour in tutorial drawings. You say this only happens with one alignment, and the other alignments in the drawing work as expected? What happens if you delete the Shortcut for that specific alignment and recreate it, do you get different results?
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
grantc
Message 3 of 7 (332 Views)
08-25-2010 06:10 AM in reply to: SethHall
I had the same problem yesterday hapeened on 3 out of 5 alignments I did an  undo and imported the profiles in first and that brought the alignments in and it seemed to work fine Im running C3D 2010 version 4
Active Contributor
randoshadow
Message 4 of 7 (319 Views)
08-25-2010 08:27 AM in reply to: SethHall
I have removed the shortcuts and recreated them, i have actually deleted the profiles and recreated them in a profile. I have done everything short of starting from scratch. I would be farely simple to just start over on the profiles but I have a very complext corridor using the alignment as a baseline that is stopping me from just starting over
Member
mike.monical
Message 5 of 7 (119 Views)
04-10-2012 01:52 PM in reply to: randoshadow
Has any progress been made on this issue?
I am having the same issues with several alignments.
The fix of deleting all data shortcuts for that alignment and starting with the design profile reference appears to work to fix the issue.  This is not a good fix as you loose any customization work you may have had for the alignment.
Does anyone know what causes this?  How to avoid it?  A better work around?
Thanks for any tips you may have.  I have 10 more sheets to do and hope to find a better way.
Mike
Member
mike.monical
Message 6 of 7 (97 Views)
05-14-2012 11:32 AM in reply to: mike.monical
This appears (in my 2012 drawings) to be a bad data ref.  Deleting the data refs and recreating the data ref resulted in no problems with duplicating the alignment definitions.
Distinguished Contributor
wdbar
Message 7 of 7 (86 Views)
05-15-2012 06:17 AM in reply to: randoshadow
I've had luck in the past by modifying the data shortuct with the data reference editor to make the shortcut read 'name only' and then re-establishing the data reference.
