Guys,
I've recieved this file from a surveyor, and I'd like to get a point list and surface out of it. It looks to me like the points may have been AECC objects at one point, but are now acting like just dumb adsk blocks. I'm using C3d 09, and have tried using data extraction to get at least x,y,z data into a csv file (it'd be nice if descriptions came too), but I appear to be missing something. I don't seem to be able to select the point blocks. From what I've been told, this is the only file/information the surveyor still has of the site, and I'm not sure what process he used to create it.
I figure if push comes to shove, I can create the surface from the contours. Would someone out there give me an idea of what I may be dong wrong with the data extraction, or if it can be done at all?
Thanks!!
Reid
Solved by TerryDotson. Go to Solution.
Try the attached AUF point file, exported from MapWorks Points after using it's Convert Blocks tool to create Civil3D points inside the drawing, deleting the anonymous blocks. Pan around and verify the results as I only did a quick convert.
You weren't doing anything wrong, the data extraction command doesn't appear to eat anonymous blocks.
Terry,
Thanks very much for doing this. There were some minor edits required, but nothing major. As work picks up, I'll need to give your products some serious review.
Reid
What a great way to sell software, "Here, let me do this for you. See how easy that was? Now, next time you can do it all by yourself if you pay me a fraction of what I just saved you." I wonder if used car dealers could apply this technique... probably not.
