Hello
i made a profile of the road. Now i get for the existing and proposed ground the same data althougt in profile i made elevation 1 data and elevation 2 data. But the results are the same data. What i missed? Help
Solved by wfberry. Go to Solution.
1. Do not use Doc files, most people will not open due to Virus problems.
2. Open the Profile View Properties of this particular profile.
Go to the Bands Tab.
Notice the slider at the bottom, move it over until you seet Profile 1 & Profile 2.
Select the proper ones here.
Bill
Is the DWG small enough to post it? Would be a lot easier to check.
