New Member
jholt
Message 1 of 3 (146 Views)
Data Connection to SHP info not submitting to plot style
146 Views, 2 Replies
01-07-2014 07:06 AM
I have several SHP Connections that I am using as background. I can use the Style Editor to get the individual SHP Lines/Polygons/blocks to be the appropriate colors for the information that they include (Property Lines, Buildings, Utilities, etc)
The problem is in plotting this information. The settings in my tried and true .ctb file don't seem to apply to the SHP data. Everything else that actually exists in the drawing behaves correctly, but the SHP data plots as it appears on the screen.
I am using C3D 2012
Thanks for any help
As you have observed, data imported with the Data Connection functions (Feature Data Objects) will plot as they are displayed.  They do not use plot styles the way typical AutoCAD entities do.  You will need to set the style properties of the data connection layers to appear how you want them to appear on the plot.
Data Connection is a Map 3D function.  The people in the Map 3D forum may be able to provide more help on this topic.
Valued Mentor
david.zavislan
Message 2 of 3 (120 Views)
Re: Data Connection to SHP info not submitting to plot style
01-08-2014 08:08 AM in reply to: jholt
David Zavislan, P.E. | Wood Rodgers, Inc.
Valued Mentor
KirkNoonan
Message 3 of 3 (112 Views)
01-08-2014 10:28 AM in reply to: jholt
The Map objects take their colors literally. If you change them to black, they will plot black. Makes it hard to see them on the screen, though. I usually use a shade like 251. Sometimes, when it is really being a PITA, all you can do is use the 'export to dwg' tool and fix it that way.
