Showing geometry point labels isn't my problem. I'm trying to find a way to force the viewport to show bottom of the profile first. If the existing grade doesn't show up in the viewport then I can change the data band initial elevation. I'm trying not to have to manually pan each and every viewport to get my profile to show correctly.
I'm using plan and production tools to create my profiles. This is what I would like it to do and need to know if it is possible to force it to do it.
I have a profile that goes from 0 to 100 and my existing grade is around elevation 75. I would like my viewport to show elevation 0 (where the data band is located), even if I can't see my existing grade of elevation 75. Then instead of panning around my viewport I can change the initial profile elevation in the properties from 0 to say 50 so that my elevation 75 shows up nicely.
Each time I've tried creating a profile it seems to center the existing grade in the viewport and doesn't even attempt to show the data band first.
I hope this has made my predictament a little more clear. I've searched the forums, but haven't seen anything like this though I could have overlooked it.
Any and all help will be greatly appreciated.
Bryan Collins (Cadd Technician)
Bryan Collins
Cadd Technician
Windows 7 Prof w/ SP1, 64bit, Xeon 3Ghz, 16GB
Civil 3D 2013
