New Member
0 Kudos
Post 1 of 9
Cvil Cad is not compatible with windows 8??
967 Views, 8 Replies
01-13-2013 08:36 AM
I recently install Autodes Civil Cad 2013 and 2012 in my PC wit windows 8 and the program crash every 5 to 10 minutes, does somebody knows how to fix this poroblem????
343 Kudos
Post 2 of 9
Re: Cvil Cad is not compatible with windows 8??
01-13-2013 09:04 AM in reply to: luiscelis58
none of the mainstream Autodesk products are officially supported on windows 8. I'd doubt very much if any backwards compatibility will be maintained although it'd be a safe bet that future versions will be windows 8 compatible.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
199 Kudos
Post 3 of 9
01-13-2013 10:17 AM in reply to: luiscelis58
Try a Google search. You are not the first to attempt to use C3D in Win 8. You my find a way to get it working.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
308 Kudos
Post 4 of 9
01-13-2013 10:31 AM in reply to: luiscelis58
Just as an FYI, a local client was having the same issue. We had him uninstall Civil 3D and then re-install using Windows 7 Compatibility Mode. Now he's up and running and has reported no crashing.
Best regards,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
343 Kudos
Post 5 of 9
01-13-2013 11:07 AM in reply to: luiscelis58
whilst it is possible to run under windows 8 according to various posts on discussion forums do not expect any help from Autodesk if you need to troubleshoot problems.
neilyj
288 Kudos
Post 6 of 9
01-13-2013 04:24 PM in reply to: neilyj
Actually, Autodesk has said they will support Windows 8 users.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617 attempt to
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
343 Kudos
Post 7 of 9
01-13-2013 10:47 PM in reply to: luiscelis58
autocad and civil 3d ??
neilyj
Distinguished Mentor
37 Kudos
Post 8 of 9
01-14-2013 04:01 AM in reply to: luiscelis58
C3D 2012 & 2013 is not stable on Win8. Most report C3D 2013 with SP1 works well.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
169 Kudos
Post 9 of 9
01-14-2013 06:25 AM in reply to: michael.robertson
I am running it on Windows 8, WITHOUT SP1 and it works fine.  However, it is not supported.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
