Civil 3D Forum
Cvil Cad is not compatible with windows 8??
8 REPLIES 8
Message 1 of 9
luiscelis58
1630 Views, 8 Replies
I recently install Autodes Civil Cad 2013 and 2012 in my PC wit windows 8 and the program crash every 5 to 10 minutes, does somebody knows how to fix this poroblem????
Tags (2)
8 REPLIES 8
Message 2 of 9
neilyj666
in reply to: luiscelis58
none of the mainstream Autodesk products are officially supported on windows 8. I'd doubt very much if any backwards compatibility will be maintained although it'd be a safe bet that future versions will be windows 8 compatible.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 9
Neilw_05
Try a Google search. You are not the first to attempt to use C3D in Win 8. You my find a way to get it working.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 4 of 9
tcorey
Just as an FYI, a local client was having the same issue. We had him uninstall Civil 3D and then re-install using Windows 7 Compatibility Mode. Now he's up and running and has reported no crashing.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 5 of 9
neilyj666
whilst it is possible to run under windows 8 according to various posts on discussion forums do not expect any help from Autodesk if you need to troubleshoot problems.
Message 6 of 9
mathewkol
in reply to: neilyj666
Actually, Autodesk has said they will support Windows 8 users.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617 attempt to
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 9
neilyj666
autocad and civil 3d ??
Message 8 of 9
C3D 2012 & 2013 is not stable on Win8. Most report C3D 2013 with SP1 works well.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 9 of 9
I am running it on Windows 8, WITHOUT SP1 and it works fine.  However, it is not supported.
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Rail Community
