Civil 3D Forum
Cutting Volumes along a set line
6 REPLIES 6
Jestoner
357 Views, 6 Replies
I apologize if this has been posted but i wasn't sure how to search for it and my searches came up a bit empty handed.
I am attempting to take two surfaces and cut straight down through a set polyline and get the difference between two surfaces.  Do i want to use the bounded volumes to do this? Or can i simply create two surfaces and and use the analyze/volumes tool and just select the two.  I would then add the boundary to each surface to limit the data.\
My concern is since the two surfaces do not meet along the edges which will cause the math to be off.
6 REPLIES 6
troma
in reply to: Jestoner
I've never used the 'Bounded Volumes' tool, but I guess it will probably work.
Otherwise, just make a new surface, paste one of your surfaces into it, and add the polyline as a boundary. Then you can use the regular volume analysis or a TIN volume surface. Either way will work. So long as one surface is totally within the bounds of the other, I've never had problems.
Mark Green
Working on Civil 3D in Canada
Jestoner
in reply to: troma
Thank you so much, that's what I tried first I just wanted to verify my solution was correct.  I tend to second guess myself a lot as i am still fairly new to Civil 3d tools.
ccoles
I use 'bounded volumes' all the time, and have checked to make sure the bounded volumes still add up to the full surface volume. The checks always come out right. It makes separating volume areas within your design a quick, easy task.
In the Volumes Dashboard in C3D 2013, They have taken bounded volumes to a whole new level, and I like the way it does the volume reports and separates the bounded volumes within the tool and on the reports. If you are running 2013, you should check it out.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
neilyj666
Jestoner wrote:the data.\
The calcs will be correct as it is just a cookie cutter type calculation (i.e. vertical) but practically you might miss some volumes (in the slopes) at the edges which could be a problem
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jestoner
in reply to: neilyj666
That should have been the question i asked, whether or not it sliced straight down, thanks!
ccoles
Yes, it cuts up and down, like a wall at the polyline.
Windows 7 64-bit
Civil 3D 2013
Rail Community
