Hello- I did custom point codes on my corridor for labeling purposes, however there are some stations that the codes won't label. I can see the markes for the codes, and my code set style has the proper labels I want to show. There is only like 3 or 4 stations that this happens, the rest show up fine (within same region) as they should. Any ideas why this happens?
@f_bobadilla wrote:Hello- I did custom point codes on my corridor for labeling purposes, however there are some stations that the codes won't label. I can see the markes for the codes, and my code set style has the proper labels I want to show. There is only like 3 or 4 stations that this happens, the rest show up fine (within same region) as they should. Any ideas why this happens?
What version and service pack are you using? Can you post a screenshot showing what you're talking about?
