Civil 3D Forum
Cut/Fill's from Cross Sections
8 REPLIES 8
Message 1 of 9
8448 Views, 8 Replies
I am working on a project for a park in which they are looking for a new access road and a parking lot.  I created the road and sections for it, now im looking to get material cut/fill from the sections.  I am having a tough time getting them to work.  The only thing I can get to work is if i created a volume surface comparing my eg to my fg surface.  That will give me a cut and fill material amount for my new road
What i am trying to get is the volume report for each sections, so i can get the cut/fill for each section.  I have followed the tutorials and tried everything, but nothign seems to work.  I created a surface from my corridor, and for some reason when i go to edit my materials, i cant add my proposed surface from my corridor to make the comparison from, and i think thats my problem.  Everytime i go to create my volume report, i get all 0's.
can anyone please point me in the right directions or if there aer some better step by step directions on to complete this task, that would be great
Thanks for any help!
8 REPLIES 8
Message 2 of 9
ToddRogers-WPM
In order to get volumes for cut and fill on your x-sections, you first have to build a corridor surface.  Add the top or datum as a link.  Then compute materials from the Analyze tab.
Todd Rogers
Message 3 of 9
odoshi
The proposed surface you extracted from the corridor will not show up as available in a material list until you add it as a samples source under your sample lines.
If you cut your sections first, then extract a road surface, you have to go back and add it as a sampled source, then you can use it in your material list.
After that, look into plotting the section volumes next to the section views, or make a total volume table off to the side.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
Message 4 of 9
Jay_B
Be sure to create a datum surface of the corridor first, prior to creating the material list.
When creating the Materials list you'll want to set your EG surface & Datum surface to calculate the raw cut/fill section volumes..
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 5 of 9
Thanks for all the help.... I created a volume tin surface to compare the 2 surfaces (existing ground and corridor surface), and I get the total cut volume ( I surveyed the bottom of a lake for dreging, so its all cut). But when I do a report per station and get a total number of cu yards of cut, it differs from the volume surface?? any suggestions?
Message 6 of 9
The volume from surface comparison and volume from end areas or cross section will always be slightly different, because they are calculated differently.  But you do have to look at that difference and see if it is acceptable.  This is the reason that we write specifications that say we pay on the End Area method.
Message 7 of 9
Hammer.john.j
It should differ from the volume surface because the volume surface is sampling at nearly infinite levels of accuracy. The average end area method, which computes at cross sections is only as accurate as your section frequency because everything inbetween the sections is averaged out. Unfortunately, the volume surface is the right one... if the plans have a high detail you'll get the volume surface. then again, there are a lot of factors such as fluff factors, compaction and other things that'll make your EW and the actual EW off.... unless of course you spend a lot of time calculating all of that.
John Hammer, LA/CADD Manager
Message 8 of 9
jmayo-EE
Just note the Section View Tables can be had without a corridor. Two surfaces and a quantity takeoff (Materials List tab of sample line GROUP properties dialog) should be the min data you need. After you have this you should just be able to tell C3D to create the Section View Tables when you create the cross sections.
John Mayo
Message 9 of 9
Shubz26
I'm having the same issue, anyone with a solution to this?
Civil 3D 2020
Intel Xeon CPU W3550 @ 3.07GHz
Nvidia Quadro 2000
25GB RAM
Windows 7 Enterprise 64 Bit
Rail Community
