Civil 3D Forum
Cut / Fill Map
5 REPLIES 5
dibr0804
2051 Views, 5 Replies
Cut / Fill Map
Hi, I am trying to create a map/plot that will display the cut / fill areas of two surfaces with labels that state cut and fill elevations (ex. a contour line that says Cut 1' or however it labels it..)
Also In the cut areas I want the minors to bed red and the the major to be yellow and for fills I would like the minors to be blue and the majors to be green.. I am not sure what the easiest way of doing this is..
5 REPLIES 5
AlmasSuljevic
in reply to: dibr0804
Hi dibr0804,
I believe you may find this article interesting. http://beingcivil.typepad.com/my_weblog/2009/02/color-cutfill-surface-labels.html
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
dibr0804
in reply to: AlmasSuljevic
Thats exactly what I want, but is there a way instead of having the labels colored I could color the contours as well?
AlmasSuljevic
For that I would suggest using user-Defined Contours. Please see following article which explains User-Defined contours it in greater detail:http://cwcivil3d.blogspot.com/2006/11/user-defined-contours.html
Almas Suljevic
Autodesk, Inc.
This also solved my same issue, however, I am getting the "cut" labels in the fill area, along with the "fill" labels.  Do you know what would cause that?
Kevin
BrianHailey
Almas,
I believe what you meant to recommend was a contour analysis. This allows the contours to be colored based on different elevation ranges. The user defined contours allow a contour of any elevation to be created.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
