kiyabole
Message 1 of 9 (507 Views)
cut file conditional subassembly
507 Views, 8 Replies
11-09-2012 01:29 AM
how can one create the cut file conditional subassembly or the horizontal conditional subassembly using subassembly composer? if i get the idea i think life will be soooo easy
Kiya Chemeda
Civil 3D 2013
HP Pavilion dv6 cor i7
16GB RAM
windows 8
Employee
peterfunkautodesk
Message 2 of 9 (495 Views)
Re: cut file conditional subassembly
11-09-2012 06:23 AM in reply to: kiyabole
Conditionals (if/then) switches are part of Subassembly Composer. There should be examples in the help system that show how to use those. For the cut/fill what you'll do is set a target surface in the subassembly and then test your points to see if they are above or below that surface.
Peter Funk
Peter Funk
kiyabole
Message 3 of 9 (470 Views)
11-10-2012 01:14 AM in reply to: peterfunkautodesk
what i want isjost to creat the conditional and it shows as a layout as the cut fill assemly which comes from out of the box does. i can use the subassembly composer well just i can creat the condition.
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
kiyabole
Message 4 of 9 (469 Views)
11-10-2012 01:21 AM in reply to: kiyabole
What I meant was that I can use the switch, decision and all just what i dont knw is tht when the decision is true wt should i put and when the decision is false wt should i put when creating so tht the conditional subassemly does work as the out of the box cut fill sub
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
mathewk
Message 5 of 9 (463 Views)
11-10-2012 02:37 AM in reply to: kiyabole
Somepne please tell me that I'm wrong here but...
The subassembly composer has tools for conditional testuing but it can't behave exactly as the out of the box conditionals do. The OOTB subs have code inside them to "Stop processing", meaning if the condition is met or not, nothing is actually drawn. The user specifies what happens next.
The SAC does not have this, you have to draw something following each condition. You can't have those 2 branches in layout mode that the OOTB conditionals do.
Again, I'm not quite 100% on this but I had the same question as you a while ago and got this answer.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
kiyabole
Message 6 of 9 (460 Views)
11-10-2012 02:48 AM in reply to: mathewk
That aint good coz ppl want other types of condition other than the OOTB. and i do it all in sub composer bt i have to creat the whole assembly like the lane ditch and daylight together to achive wt i want and i dnt want tht coz it is difficult to manupilate
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
kiyabole
Message 7 of 9 (441 Views)
11-10-2012 11:08 PM in reply to: kiyabole
Normaly what i doo is creat the whole one side as one but tht is not flexable to work on different project
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
LeafRiders
Message 8 of 9 (398 Views)
11-26-2012 04:05 PM in reply to: kiyabole
They called it Subassembly Composer for a reason. There is a huge advantage to creating Custom SAs as independant SAs vs. all as one complete one.
Now looking back on a library of custom SAs it's worth the effort to keep that thought process in place. As for adding a condition to a Custom SA, you will need at least two applications. If you have one on one side in that said condition, have option 1 do what you want it to do, and in option 2 have it draw a line at 0.
Having your next SA attached to that should give you options.
kiyabole
Message 9 of 9 (389 Views)
11-26-2012 11:42 PM in reply to: LeafRiders
What Do You mean by two applications? What i want is just to have a dicition where when true it will do wt is attached to tht conditional sub on the assembly  and if false to stop
Kiya Chemeda
Civil 3D 2013
16GB RAM
windows 8
