I'm doing cut and fill for alley sections and getting fill shown to top of paving sections. Is there a way to keep the table from calculating fill for portions that are pavement?
Solved by Civil3DReminders_com. Go to Solution.
I may be wrong, but you may need a dummy profile for the concrete.
You create a datum surface, same way you did for the top, but use the datum link.
I have a datum surface that is the cut target. For the fill however its using the Top surface but that puts fill in areas that will be pavement. Thats what I want to eliminate from the fill area.
Then you need to make sure your material quantities are using the datum surface. Sounds like it isn't.
I've attached a screen shot of my materials list.
That seemed counter-intuitive when first reading but it did the trick. Thanks
