Member
0 Kudos
Post 1 of 6
Cut and fill to specific elevation (BFE)- For FP Mitigation
390 Views, 5 Replies
01-29-2013 07:57 AM
I need to figure out the amount of cut and fill up to a specific elevation, the Base Flood Elevation.  Right now, I am creating the proposed and existing surfaces in Civil 3D and making a fellow coworker convert it to Eagle Point to generate this slice Volume Table. See attached PDF.  Is there a way to generate this type of table in Civil 3D? Any ideas?  Thank you!
169 Kudos
Post 2 of 6
Re: Cut and fill to specific elevation (BFE)- For FP Mitigation
01-29-2013 09:41 AM in reply to: amybrammer10
Is this what you're looking for?...
This can be exported out to a TXT file.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
4 Kudos
Post 3 of 6
01-29-2013 10:44 AM in reply to: amybrammer10
Another option is to set a user contour to your required elevation.  Extract the contour as a polyline and use it/them as a boundary.  Even if the boundary is only temporary.
You may have to edit them a bit to get the desired results.
Conan Witzel
Member
0 Kudos
Post 4 of 6
09-16-2013 01:24 PM in reply to: TRogers
Yes but how do I compare the existing and proposed surfaces? It only allows me to select one of the surfaces. Thank you for your help!
Member
0 Kudos
Post 5 of 6
09-16-2013 01:29 PM in reply to: amybrammer10
I am trying to do a volume comparison between the proposed and existing surfaces and have to show the cut/fill volumes in one foot increments.
169 Kudos
Post 6 of 6
09-16-2013 01:33 PM in reply to: amybrammer10
Type REPORTSURFACEVOLUME and you can get a volume that way.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
