Civil 3D Forum
Cut and fill to specific elevation (BFE)- For FP Mitigation
5 REPLIES 5
amybrammer10
1419 Views, 5 Replies
I need to figure out the amount of cut and fill up to a specific elevation, the Base Flood Elevation.  Right now, I am creating the proposed and existing surfaces in Civil 3D and making a fellow coworker convert it to Eagle Point to generate this slice Volume Table. See attached PDF.  Is there a way to generate this type of table in Civil 3D? Any ideas?  Thank you!
5 REPLIES 5
Is this what you're looking for?...
This can be exported out to a TXT file.
Todd Rogers
witzel
in reply to: amybrammer10
Another option is to set a user contour to your required elevation.  Extract the contour as a polyline and use it/them as a boundary.  Even if the boundary is only temporary.
You may have to edit them a bit to get the desired results.
Conan Witzel
Yes but how do I compare the existing and proposed surfaces? It only allows me to select one of the surfaces. Thank you for your help!
amybrammer10
I am trying to do a volume comparison between the proposed and existing surfaces and have to show the cut/fill volumes in one foot increments.
Type REPORTSURFACEVOLUME and you can get a volume that way.
Todd Rogers
Rail Community
