Valued Contributor
Joyfer
Message 1 of 9 (382 Views)
cut and fill report
382 Views, 8 Replies
02-08-2013 08:34 PM
Does any one know of any literature that could help me with making my cut and fill reports more accurate?
The main question I have is when should I delete lines in my surface, so if there is literature on how to manipulate surfaces created from survey data that would be perfect.
Thanks again everyone,
Joy
neilyj
Message 2 of 9 (364 Views)
Re: cut and fill report
02-09-2013 01:39 AM in reply to: Joyfer
not sure exactly what you mean by delete lines but the main reason for deleting lines is to ensure that the TIN forms correctly in certain areas of the model especially at the external boundary. help has much info on this
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Contributor
Joyfer
Message 3 of 9 (354 Views)
02-09-2013 07:45 AM in reply to: neilyj
Well I'm given survey data points. All I know to do with it is to make a surface and delete the triangle lines around the outer edge that go further beyond the points (if there is a curved line the lines will extend to the peaks of the curves, that's what I'm talking about). Also there seems to be clusters of points and I feel like I sould delete triangle lines around the boundaries of the clusters too but I definately would like to know how other people do it.
Let me know if that makes since.
Valued Contributor
Joyfer
Message 4 of 9 (348 Views)
02-09-2013 09:12 AM in reply to: Joyfer
But I am having more issues than that, I am getting 1,000 cubic yards cut and the other contractors get 3,000 cubic yards. That's why I was wondering if there was some document that could walk me through the process of making monthly cut and fill reports.
neilyj
Message 5 of 9 (334 Views)
02-09-2013 01:24 PM in reply to: Joyfer
how are you doing the monthly calculations at the moment.?
neilyj
Valued Contributor
Joyfer
Message 6 of 9 (329 Views)
02-09-2013 03:17 PM in reply to: neilyj
I was given a base ground topo drawing and they gave me four sets of monthly topo (Sept. - Dec.). I pasted Sept - Nov. surfaces to the base ground surface. Then used that as a comparision surface and the Dec. topo as the base surface in a tin volume surface in order to make a report for December.
I just came up with that method by watching youtube tutorials, and would love to know the way profesionals do it.
I appreciate the help.
Jay_B
Message 7 of 9 (322 Views)
02-09-2013 06:29 PM in reply to: Joyfer
There is a AU class on the concept your dealing with which focuses on keeping your model updated throughout construction. I attended the class and it can be found at:
http://au.autodesk.com/?nd=class&session_id=10712
Class name: Surveying: Cleaning Your Dirt Data
If you haven't created an AU account you'll need to do that before you can watch the class.
There are also course materials available.
Jay
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Contributor
Joyfer
Message 8 of 9 (314 Views)
02-09-2013 08:31 PM in reply to: Jay_B
Thank you Jay, I am checking that out now.
Distinguished Contributor
area51visitor
Message 9 of 9 (303 Views)
02-10-2013 12:38 AM in reply to: Joyfer
Sounds like you might be missing breaklines. I wouldn't recommend modifying the surface in any way in a conditions such as this, except to stay within the limits of your survey (as you noted cad tends to connect things it shouldnt). The most accurate way to build a surface is with points and breaklines connecting those points. Breaklines are the "hinges" in the ground... such as the top of a ditch, bottom of a ditch, bottom of a stockpile, etc.  If your surverors didn't shoot those so you can develop those breaklines it will be difficult to complete a very accurate surface.
- Brian
"Very funny, Scotty. Now beam down my clothes."
