Probably missing a step somewhere...
I'm cutting and pasting an alignment object from one C3D drawing to another, however the alignment does not appear in the prospector
Solved by Jay_B. Go to Solution.
Not sure why your cutting and pasting this alignment but here are a couple of options that will work
to copy / share the alignment from one dwg to another.
then Data Shortcuts are the way to go.
Alignment into dwg B and "promote" it.
