Civil 3D Forum
Customizing Reports in Reports Manager
3 REPLIES 3
cyberflow
2344 Views, 3 Replies
Hi there,
I'm wanting to customize my Reports in the Reports Manager.
I noticed that the XSL files are stored here :
C:\ProgramData\Autodesk\C3D 2014\enu\Data\Reports\Net\Source\
My first question is : How can i make different directories of reports ?
(See printscreens)
From this :
To this :
Id like to have different directories, example : One for city client, one for our office, etc...
And i noticed that when you press this icon you can change the information in the client
Is the information associated to Civil 3D or i can create different client info's for each client in their respective template ?
Using : Autodesk Civil 3D 2022& 2023
AKA Frank Freitas, Senior Roadway Designer @ Kiewit
3 REPLIES 3
cyberflow
in reply to: cyberflow
http://blog.civil3dreminders.com/2014/05/adding-arborescence-to-toolbox.html
Found a partial answer here.
Still asking myself it's possible to manage several clients in the Client information tough
Jeff_M
The Company/Client data is saved here:
C:\Users\USERNAME\AppData\Local\Autodesk\LandXML Reporting\RepGenSettings.xml
The only way you'd be able to maintain different clients would be to copy this file for each client. Then copy it back to this named file when needed. I'm sure it could be done easier with a bit of programming.
Jeff_M, also a frequent Swamper
cyberflow
in reply to: Jeff_M
Thanx Jeff_M
Good to know where are the files that C3D points to !
Il'l try to build up something from that.
Rail Community
