Hello all,
Maybe I shouldn't have switched to C3D 2015 so early, but I'm hoping that's not the "solution" to this problem.
Here's what's up. I have a viewport which I need to set to a certain scale. I click into the viewport from paper space. Then I go to the bar on the bottom of the screen and click the viewport scale menu. There are several scale options to choose from, none of which suit me, so I click "Custom.." so I can make a new scale, as I have always done for the last 3 releases of AutoCAD.
BOOM, CRASH.
The window reads this:
AutoCAD error abort
"Error handler re-entered. Exiting now."
We have replicated this problem on another computer with a different file.
Someone showed me another way to set the scale in viewports, but I would still appreciate still if Autodesk would address this problem.
Solved by mathewkol. Go to Solution.
Solved by Cadguru42. Go to Solution.
I always have my PROPERTIES box open. Select the "frame" of your viewport. In the Viewport of the Properties box is all the help you will need that can be adjusted.
Bill
Try SCALELISTEDIT.
Edit: I've seen other posts reporting the same issue. So please report the problem to Autodesk here: http://download.autodesk.com/us/support/report_a_bug.html
Interestingly, issuing that command from the command line causes the same crash. I reported the problem.
I am not able to edit the scale of my viewport from the properties box. It does list the current scale, but locks me out from editing it. Can you be more specific, maybe I'm looking at the wrong thing?
I was working on an existing drawing today, and I did not even have to create a custom scale. Simply trying to SET a different scale caused it to CRASH.
After 5 or 6 more tries and crashes, I opened the drawing in 2013 and it worked fine. I hope SP1 is coming soon and that it fixes basic functionality like this. I think I've submitted more CERs in one week of 2015 than I have all time for 2013. 😞
This is a known bug (#34 on my list) that Autodesk has supposedly fixed in the soon-to-be-released C3D 2015 SP1. If your drawing was created using any of the OOTB C3D tempaltes (not acad.dwt) then the crash will happen. If you create a new template based on the no template option, then transfer styles, layers, blocks, etc. into it then you won't get this issue.
I shall await the service pack then.
BTW not sure if the other posters on the thread knew the workaround, but what you need to do is:
Double click in the viewport
Enter Z for zoom in the comand line
Type in "xp(your scale) i.e. "xp1/2" to get 1"=2'
FYI, the service pack did, in fact, fix this issue.
It doesn't appear to have fixed the issue here, we have a couple people with this issue and it still occurs after the service pack has been installed.
Unless I still have to go through some process of fixing the corrupted files before they'll work correctly?
Also, it appears that once a drawing has this issue in 2015, the crashing carries over to 2014 as well, which is rather inconvenient and frustrating. Anyone else seeing this?
We have about 9 seats of IDSP.
Two of my users had this issue.
SP2 fixed one of them but not the other.
We're trying some of the workarounds now.
Nevermind. I should have gone to physically see what was going on. It was just a matter of the Scale List dialog box being off the screen. Alt+Space > Move did the trick to bring it back. So, service pack 2 did the trick afterall.
