I am having trouble using imported custom subassemblies. I get the following message in the event view when i try to attach a subassmbly to an assembly:
[Something wrong with current subassembly: Failed to create a 'Settings' from the text 'Assembly references and imported namespaces serialized as XML namespaces'.] (Source: Subassembly.CC_Guardrail_Type_31
I am using Civil 3d 2013 version on a windows xp 32 bit machine.
People who use Subassembly Composer 2013-2014, don't install 2013 SP2 and 2014 hotfix 1 because you will get
an import error message.
Mark Green
Working on Civil 3D in Canada
This solved my problem.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-2013-Servicepack-2/td-p/4357336
Yep Install DOT NET 4.5. Subassemblies now work.
